Date/Time: Sun, 21 Jun 2026 23:43:06 +0000
Live orders disappearing
View Count: 1250
| [2021-11-03 14:23:16] |
| Tonkadad - Posts: 235 |
After initiating a position with bracket orders, orders disappear on SC with the sound like stop got hit but price not near stop. Still have original position with broker, after a few seconds the position line comes back on SC. Flatten does not get me out of trade, if short I have to initiate a buy to get flat. This has happened off/on over a span of weeks. Doesn't happen all of the time. IB broker, Denali feed, NQ is the instrument. SC ver. 2323 Date Time Of Last Edit: 2021-11-03 14:24:10
| [2021-11-03 18:48:22] |
| Sierra_Chart Engineering - Posts: 24083 |
Check to see if you see the position in Trade >> Trade Positions Window. If not then Interactive Brokers is not providing it. Also look at the Service Position Quantity field. The issue might be related to a delay with that. If that is delayed, then the position could disappear then come back after a few seconds. Also refer to: Trading Information Windows: Incorrectly Reported Trade Position Quantity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-03 18:49:46
| [2021-11-17 16:03:47] |
How do I troubleshoot the problem I am having: no orders placed with IB when trying to buy 1 share of TSLA (TSLA order) Cancel All doesn't affect the order, Flatten doesn't affect the order. Using the same chart I switch to another stock it works except sometimes the position line disappears. How can I start fresh with the trade window? Reinput everything? Date Time Of Last Edit: 2021-11-17 16:04:21
| Attachment Deleted. |
| [2021-11-18 09:31:27] |
In the Trade and Current Quote Symbol box, in Chart Settings: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) use the complete Interactive Brokers symbol for this stock: Interactive Brokers Symbols: Stocks With Specified Exchange and Primary Exchange Format and enable this setting: Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-18 09:33:02
