Date/Time: Mon, 03 Mar 2025 10:32:01 +0000
Can't get currency 4 hour charts to load before August 4, 2021
View Count: 422
[2021-11-02 20:30:06] |
ssangha84 - Posts: 126 |
Hello, I can't seem to get any data to load before August 4, 2021 on Intraday charts. On Daily and weekly it loads fine, but not intraday. I tried changing the dates under chart settings, but it just changes back to August 4 automatically. And when I increase the number of days where it says "Days to Load", it does nothing. Can you please let me know what I am doing wrong? Thanks.
[2021-11-02 23:40:28] |
John - SC Support - Posts: 38292 |
First, refer to the following: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Then, if this does not resolve your issue, we need to know the exact symbol for which you are having an issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-03 10:24:16] |
We see you are using CQG. To be able to use the Continuous Futures Contract chart feature, which is necessary to do what you want, you need to use the Denali Exchange Data Feed: Denali Exchange Data Feed Refer to the highlighted section in the Introduction section here about this: Continuous Futures Contract Charts: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-03 10:32:07
