Date/Time: Mon, 03 Mar 2025 10:41:25 +0000
[User Discussion] - Number Bars Calculated Values as a histogram
View Count: 856
[2021-11-02 15:19:13]
manfretto - Posts: 117
I use Number Bars Calculated Values to show two type of delta. All in figures. What function should I use to change table with figures into histogram chart for two deltas?
[2021-11-02 15:33:21]
User907968 - Posts: 833
Study Subgraph Reference
Study Subgraphs Reference
Spreadsheet Formula
[2021-11-02 16:09:05]
I have almost managed with Study Subgraph Reference. How can I show all delta (positive and negative)above zero as a histogram?
[2021-11-02 16:18:32]
You could the spreadsheet formula study mentioned above and invert the negative delta for example: =IF(BV>AV,(AV-BV)/V*-1,(AV-BV)/V)
Or
If you want different colors for each of pos and neg delta, use two copies of the study, for example:
Pos: =IF(AV>=BV,(AV-BV)/V,0)
Neg: =IF(BV>AV,(AV-BV)/V*-1,0)
[2021-11-02 16:22:47]
I have used study subgraph reference. Can we make it via this?
