Date/Time: Mon, 03 Mar 2025 10:43:36 +0000
Change symbol based on Active Chart
View Count: 544
[2021-11-02 14:39:01]
User606491 - Posts: 164
I use a sub-set of lower time frame charts to confirm my entries. I also "watch" several symbols simultaneously. Rather than have a lower time frame chart for each symbol, is there a way to link symbols based on which chart is active?
For example, if I click on /ES, then my lower time frame charts would load /ES; if I next click on /CL, then my lower time frame charts would load /CL.
Also open to other alternatives for minimizing the number of charts that must be kept open while watching multiple symbols.
As always, thanks,
[2021-11-02 16:32:23]
John - SC Support - Posts: 38292
There is not a way to do exactly what you are asking for.
But, you could use the Chart Linking for Symbol to change all the lower time-frame charts by changing just one of them. Refer to the information at the following link:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
