Date/Time: Mon, 03 Mar 2025 10:42:20 +0000
gebuhren
View Count: 468
[2021-11-02 14:13:25]
mchoppla - Posts: 20
Hello, I wanted to ask whether the fees for amp have already been deducted from the cash balance at sierrachart or do I have to deduct them separately? thanks
[2021-11-02 16:14:05]
John - SC Support - Posts: 38292
We do not deduct any fees for AMP, or for any other broker.
[2021-11-02 18:12:18]
okay ich danke ihnen.Kann man das vielleicht einstellen das die Gebühren mit abgezogen in der cash Balance stehen?
[2021-11-02 18:15:46]
From Google Translate:
okay, thank you. Can you maybe adjust that the fees are deducted in the cash balance?
We are not sure what fees you want to have adjusted, but it is not something that we do.
