Date/Time: Mon, 03 Mar 2025 10:37:42 +0000
i paid 46$ by mistake i wanted the 36$ advanced
View Count: 425
[2021-11-02 13:58:10]
User911074 - Posts: 1
i just paid but by mistake i did the 46$ plan and not the advanced
I have data on my tws platform
please help
just put 10$ on my balance for next month
[2021-11-02 16:10:51]
John - SC Support - Posts: 38292
Sorry, we are not sure if you want the Advanced Package or not.
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
