Date/Time: Mon, 03 Mar 2025 10:28:46 +0000
real-time data CQG
View Count: 552
[2021-11-02 13:57:58]
User57210 - Posts: 121
This morning my account (CQG connection via SC) is bringing in historical data, but no real-time data. I've spoken w/ broker and no problem on their end, and no CQG outages. Account has worked flawlessly for quite a few months until today. Please advise, thank you!
Date Time Of Last Edit: 2021-11-02 13:58:18
[2021-11-02 14:05:49]
I was running SCv2319 so i'm doing an update as we speak to see if that helps. The oddest thing is that I have run this every day for months and months with no problems, and I have not altered any settings. Just stopped working when I launched things this morning.
[2021-11-02 14:23:01]
Note after the SC update the situation remains the same.
[2021-11-02 16:28:34]
John - SC Support - Posts: 38292
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-11-02 17:01:42]
Log sent
[2021-11-02 17:22:17]
The following line in your log is the issue:
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
You are connected to the data feed from two different computers at the same time. It is best to exist from all other Sierra Charts running on other computers to ensure that you do not run into this issue.
Or, you could pay twice the amount for the exchange fees to allow 2 computers to get data at the same time. Refer to the following:
Denali Exchange Data Feed: Connections
[2021-11-02 17:44:58]
I have three instances running
1) Connected to this CQG connection (no others are using it or its data)
2) Trading Evaluator connection
3) TT/SC Order routing connection.
Should this conflict or require another purchase/configuration? I didn't think they would/should.
[2021-11-02 17:45:52]
And again to reiterate, nothing has changed about these configurations/usage going into today - it's all worked fine.
[2021-11-02 18:13:03]
Our servers are showing 2 systems running at the same time. The IP Addresses are the following:
- 69.137.123.225
- 138.128.240.206
Whichever system you are NOT running on, start Sierra Chart and then exit. Hopefully it is just a matter of our servers not having logged it properly and doing this will update it correctly.
