Date/Time: Sun, 11 Oct 2026 13:20:25 +0000
Pixels per sc.BaseGraphScaleIncrement
View Count: 2164
[2014-03-31 12:28:34]
QnReally - Posts: 188
I have an ACSIL study that prints some text labels on multiple lines. When I change the scale of the main graph to a bigger number, the labels become squished because I use label offsets based on the TICK_SIZE (I tried Relative positioning also but it gets into some issues). Is there a way to determine how many pixels are in the chart from top of the scale to the bottom? In other words, I would like to know how many pixels are being used vertically for each sc.BaseGraphScaleIncrement value in the chart.
I am using CONSTRANGE for the main graph and my study is set to Automatic scaling and it is drawn in the same region as the main graph.
This post may be a duplicate because I messed up my previous request.
Thanks.
[2014-03-31 17:15:05]
You can use the following as long as the study is set to sc.GraphRegion= 0:
https://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scStudyRegionTopCoordinate
[2014-03-31 17:33:25]
I am running v1109 and here is the code I have for the study:
sc.GraphRegion = 0;
Buffer.Format("TC = %d, BC = %d", sc.StudyRegionTopCoordinate, sc.StudyRegionTopCoordinate); sc.AddMessageToLog(Buffer, 0);
And it prints the following in the Message Log:
Chart: @NQ#C/NQM4 [R] 300 Volume #26 | Study: Test | TC = 0, BC = 0 | 2014-03-31 13:27:08
My price scale is set to Constant Range (http://screencast.com/t/KskYcIWAd). I am not sure what I am doing wrong.
Thanks.
[2014-03-31 17:41:50]
Is this line of code outside of the sc.SetDefaults code block:
Also you could gets zeros for the first call into the study function when first opening the Chartbook and the study is already on the chart.
[2014-03-31 18:30:23]
It is outside the sc.SetDefaults block. Message Log shows a new message each time I press the Insert key on the keyboard which I think is reloading the chart. Here is the skeleton of the code:
  if(sc.SetDefaults)
    sc.GraphName="Test";
    sc.StudyDescription="Test";
    //Manual looping
    sc.AutoLoop = 0;
    sc.GraphRegion = 0;
    return;
  SCString Buffer;
  if (sc.UpdateStartIndex == 0) {
    sc.GraphRegion = 0;
[2014-03-31 18:48:49]
It makes sense the top coordinate would be 0. However, notice your code, you are outputting the top coordinate twice. Not the bottom coordinate.
[2014-03-31 19:20:26]
Well, that was totally silly of me. Thanks for debugging my code. Have a great day!
