Date/Time: Mon, 03 Mar 2025 10:08:20 +0000
Losing connection
View Count: 563
[2021-11-01 18:27:27] |
12VMan - Posts: 45 |
Hello - I have had my data feed disconnected multiple times today. Charts are also running behind.
[2021-11-01 21:38:57] |
For data lag issues, refer to: Prices / Data Falling Behind For the disconnection issues, this is not something we have any control over. We see you are using Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
