Date/Time: Mon, 13 Jan 2025 11:45:14 +0000
Format timestamps on X-axis ?
View Count: 852
[2014-03-31 11:46:18] |
AndyL - Posts: 119 |
Hello, i have a tick-chart, and the timestamps on the x-axis are in hh:mm:ss format. Is it possible to set it to hh:mm format, without seconds being displayed? Regards, Andy |
[2014-03-31 16:34:34] |
No. This is not supported.
[2017-04-24 16:49:01] |
User591364 - Posts: 1 |
Hi, Three years since that question. Do you have any changes ? I am too interested to strip seconds from tick chart. Regards, Liudas |
[2017-04-24 16:59:32] |
Yes we can see about adding a setting. We will put this on our to do list.
