Date/Time: Mon, 03 Mar 2025 10:01:35 +0000
how to switch between opened chartboks with key shortcut?
View Count: 1376
[2021-11-01 17:38:12]
User30743 - Posts: 365
i have several chartbooks opened simultaneously and i want to easily switch between them.
it can be sort of a rotation eg
1] pres CTR+N >>> next
2] pres CTRL+B <<<< previous
how do i do that?
[2021-11-01 18:03:07]
John - SC Support - Posts: 38292
Previous Chartbook and Next Chartbook are tied to keys F7 and F8 (respectively) by default. You will see this in the Window menu. You can change which keys are set for these items in the Keyboard Shortcuts settings. Refer to the following:
Window, CB and CW Menus: Previous Chartbook (Window)
And refer to the following:
Keyboard Shortcuts for Menu Commands
[2021-11-03 05:59:30]
Tonkadad - Posts: 235
You can also create a Toolbar that contains all of your chartbooks and you can choose which one you want.
See attached.
Date Time Of Last Edit: 2021-11-03 05:59:49
imageSC toolbar chartbooks.PNG / V - Attached On 2021-11-03 05:59:19 UTC - Size: 6.33 KB - 258 views
