Date/Time: Mon, 03 Mar 2025 10:38:57 +0000
data flow configuration with Leeloo trading
View Count: 875
[2021-11-01 16:27:53] |
AliG7074 - Posts: 3 |
Hello, I just reactivated my Sierra Chart account my question is how to use my Leeloo Trading account on Sierra Chart the data feed I use with Leeloo is Rithmic can you help me please I can do a screen share |
[2021-11-01 17:06:38] |
John - SC Support - Posts: 38292 |
In order to connect Sierra Chart to your Rithmic account follow the instructions at this link: Rithmic Trading Platform Service: Setup Instructions Also, your Sierra Chart account from which you posted is expired. If this is your correct account, then you will need to activate a Sierra Chart package in order to use the software. Refer to the instructions here: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
