Date/Time: Tue, 26 Nov 2024 04:28:07 +0000
Cannot save a specific Volume Profile configuration as default
View Count: 1102
[2014-03-31 09:41:33] |
Zosimus - Posts: 345 |
I try to save a configuration of the Volume by price study with Extend Peaks and Valleys Until Future Intersection as the default setting (by checking the "Save these Settings as default" box) but the next time I use the Volume profile the configuration shows End Of Window instead of Until Future Intersection. I tried this a few times and also upgraded to the latest Non-CLR but the problem persists. |
[2014-04-01 09:26:17] |
We need to test this.
[2014-04-07 02:25:11] |
We cannot duplicate this problem. Are you using the Draw Volume Profile tool?
[2014-04-07 07:44:14] |
Yes, i apologize for not being clear about that. |
[2014-04-08 11:19:36] |
Al SC Developer - Posts: 434 |
This will be fixed in ver 1118.
