Date/Time: Mon, 03 Mar 2025 10:40:23 +0000
Previous high/low indicator
View Count: 2394
[2021-11-01 14:18:30] |
User525965 - Posts: 153 |
Is there an easy way to have the previous day session high and low automatically be drawn as a level on the next days chart? I see a high low indicator but it only does it for the current data period. I would want it for the previous one Thanks |
[2021-11-01 14:37:22] |
I just found the Daily HLOC indicator to work the way I would like, except is there a way to not have the lines extend all the way across my chart, would rather it just be a 2 inch line on the left side of my chart if that's possible. Thank you
[2021-11-01 15:16:14] |
John - SC Support - Posts: 38292 |
There is not an option to have a line on the left side of the screen, but you can do the right side by changing the Draw Style to Line at Last Bar to Edge. Refer to the information here: Chart Studies: Line at Last Bar to Edge (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_TO_EDGE) Or take a look at other Draw Styles to see if there is something else that might work for what you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
