Date/Time: Mon, 03 Mar 2025 10:34:30 +0000
Что с графиком?
View Count: 625
[2021-11-01 14:05:27] |
User185037 - Posts: 21 |
http://www.sierrachart.com/image.php?Image=1635775320500.png ЧТо случилось с графиком? как это исправить? |
[2021-11-01 14:32:50] |
John - SC Support - Posts: 38292 |
From Google Translate: What happened to the schedule? How to fix it?
We are not understanding your question. What exactly are you having an issue with? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-01 14:47:22] |
с 18.00 до 18.05 бары отсутствуют- точнее у них раскиданный вид. Это клиринг? так будет всегда в это время?
[2021-11-01 15:22:25] |
From Google Translate from 18.00 to 18.05 bars are absent - more precisely, they have a scattered view. Is this clearing? will it always be so at this time?
From what you state, this does not sound correct. Follow the instructions at the following link to redownload the data from the time before the bad data and see if it gets corrected after the redownload: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart If you continue to have a problem after this, then can you please attach a screenshot showing what you see. Follow these instructions to get us an image: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
