Date/Time: Mon, 03 Mar 2025 10:12:06 +0000
copy drawings to another region chart
View Count: 562
[2021-11-01 14:01:41] |
User278398 - Posts: 291 |
Hello, i changed my main chart to be at region 2 after i copy drawings from another chats, i get the copy drawings on region number 1... how can i change the region copy to be as my main region (number 2)? pic is added regards. |
[2021-11-01 14:20:28] |
John - SC Support - Posts: 38292 |
What you are wanting is not supported. We have marked this as a Feature Request.
[2021-11-01 15:32:39] |
what i really want is that: i have study (volume study for example), and i want it will be on the top of the window and below it i want to see my main gaph chart ( which include the copies of other drawings). there is an option to do that ? |
[2021-11-01 16:45:56] |
If you have the other charts setup in the same way, then the drawings will copy, but it will not work copying from one region into another region.
