Date/Time: Fri, 07 Mar 2025 01:06:34 +0000
Execute trade on two similar instruments using single chart trade window
View Count: 661
[2021-11-01 00:34:41] |
User148721 - Posts: 5 |
Is is possible to execute a trade for two different symbols but similar instruments with a single chart trade window? For example, I would like use a single chart trade window to buy or sell 1 ES contract and 10 MES Micro E-mini contracts at the same time. The 1 ES contract would have it's own attached orders scheme and the 10 MES contracts would have it's own attached order scheme. Both ES and MES orders will be for the same direction. This trade(s) would be using the same Rithmic data feed and for the same broker account. I've been using the "Trade and Current Quote Symbol" field and enabling "Use as trade only symbol" feature to chart the ES but execute trades on MES but now I want to see if there is a method to trade a combination of the ES and MES at the same time with one order entry through the chart trade window and each instrument will have it's own attached order scheme. Is this possible? Thank you. |
[2021-11-01 13:54:27] |
John - SC Support - Posts: 38467 |
There is not a built-in way to do this within Sierra Chart, but you could program a study to do it. Refer to the following: Automated Trading From an Advanced Custom Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-23 06:25:48] |
User379468 - Posts: 508 |
User148721
Were you able to develop this? |
