Date/Time: Tue, 26 Nov 2024 03:53:12 +0000
Different data
View Count: 996
[2014-03-31 02:58:50]
arrow - Posts: 52
Why would I have different data from the daily to intraday charts?
For example ZCK14
Friday 03/28/14 close on the daily is 492. on the intraday chart it's 490.5.
The open for this day on both charts is correct.
[2014-03-31 03:20:12]
This question is outside the scope of our support.
Other than to refer you to help topic 43
http://www.sierrachart.com/index.php?l=doc/helpdetails43.html
[2014-03-31 05:01:19]
arrow - Posts: 52
I forgot to mention I'm using CTS and SC vs1110
I've seen you mention vs1112 is out but mine says it's up to date when I try to download current version.
It's probably safe to say the data difference is probably a CTS issue to go along with their other issue.
[2014-03-31 07:14:02]
To update to the latest release you need to select Help >> Download Prerelease.
We should have been more clear about this. What we think this is about is documented in this particular section here (43.6):
http://www.sierrachart.com/index.php?l=doc/helpdetails43.html#h43.6
It just has to do with the settlement price.
This is not a CTS issue.
