Date/Time: Tue, 04 Mar 2025 21:14:38 +0000
AMP Futures and Sierra Chart Order Routing
View Count: 1999
[2021-10-29 07:53:39] |
User450463 - Posts: 128 |
I got an email more than a month ago, from AMP, that said they were going to be implementing your in-house order routing once "it was verified there were no issues". Their support told me that there was no further news at this time. Do you have any additional information on the roll-out? I would like to switch and get away from CQG. Thanks |
[2021-10-29 14:58:18] |
John - SC Support - Posts: 38369 |
We do not have any more information at this time. We have the implementation being used by a couple of clearing firms at this point and it is going well, so we expect to start working with AMP soon, but we really do not have any specific timeline in place yet.
[2021-11-05 10:52:41] |
2garin - Posts: 184 |
Good day. The site has information on the question: Which FCMs support Sierra Chart order routing? Date Time Of Last Edit: 2021-11-05 10:53:45
[2021-11-05 14:07:20] |
Refer to the information at Step #2 at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-06 09:57:44] |
Good day. Thanks for the help. Perhaps your answer is inaccurate: There is no FCM named Nirvana on the NFA website. https://www.nfa.futures.org/BasicNet/basic-search-landing.aspx Date Time Of Last Edit: 2021-11-06 09:58:11
[2021-11-06 10:20:10] |
Sierra Chart Direct Order Routing is the most reliable and fastest way to deliver orders to the exchange. Does this service have an additional fee? Why isn't the cost of the service advertised on an equal footing with its reliability?
Date Time Of Last Edit: 2021-11-06 10:21:29
[2021-11-07 14:53:35] |
Nirvana will just be acting as an intermediary and connecting you to another FCM. The cost for the Sierra Chart Direct Order Routing is a routing fee of $0.10 per side with a maximum of $250.00 per month. You are typically paying this already to your broker for the routing service, so we are not adding any additional fees that you are not already paying. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-05 12:26:03] |
Right now there is no cost for the Sierra Chart Direct Order Routing service which is called the Teton Order Routing service.
