Date/Time: Sun, 02 Mar 2025 22:12:36 +0000
Problem with Time moving average and Volume ( chartbook inside to see the problem )
View Count: 396
[2021-10-28 17:50:12] |
GravisHTG - Posts: 306 |
I have put a 1 DAY TMA and a 15 DAY TMA on my volume study but It does not show the right amount. I dont understand what I am doing wrong. When I click apply , it show the good value but then instantly change to another value. all i want is only to be able to compare a 15 day volume to a 1 day volume. I did the same thing for prices and It works. Do not bother about the lines , Its on a automatic recenter at every tick , 3 range. ( I remove the line when I put the numbers in my volume TAB ) Thanks Date Time Of Last Edit: 2021-10-28 17:54:40
[2021-10-28 18:34:56] |
John - SC Support - Posts: 38292 |
We need some time to look through this study. It is a bit older and it may not work exactly as you are expecting.
