Date/Time: Sun, 02 Mar 2025 22:12:32 +0000
Setup 2 connections of Denali data feed
View Count: 900
[2021-10-28 00:47:58] |
AzharBasri - Posts: 28 |
Hi, I want to setup another connection if Denali data feed on my second computer. Everything is fine with my first system, but when I do the same for my second system, there is no data feed at all. How can I do it?
[2021-10-28 01:07:12] |
John - SC Support - Posts: 38292 |
Refer to the following: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously Note the section above the one we linked above, as that gives information on connecting two different installations from the same computer to your Denali Exchange Data Feed - in which case you do not need to pay the second exchange fees. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
