Date/Time: Sun, 02 Mar 2025 22:03:51 +0000
How to connect live data with Tradovate funded account
View Count: 5582
[2021-10-27 17:33:12]
User578902 - Posts: 10
I got Denali data feed and I have a Tradovate funded account but I don’t know how to connect the Tradovate account through Sierra charts to obtain live data. I need helps it’s been over two weeks and I still have no live data
[2021-10-27 23:11:36]
John - SC Support - Posts: 38292
Tradovate uses CQG for order routing, so your account with them should have CQG credentials. As such, you will follow these instructions to connect your Sierra Chart to CQG:
CQG Trading Platform Service: Setup Instructions
You also need to fill out the Exchange Agreements and indicate that you have Tradovate for your broker and enter your account number.
If you do not want to have Sierra Chart connected to your Tradovate account at all times, then you will need to connect at least once a month in order to verify the account for the CME Group's nonprofessional classification. Refer to the following for more information:
