Date/Time: Tue, 26 Nov 2024 02:31:24 +0000
Using the percent version of Y value for the drawing tool
View Count: 1187
[2014-03-30 10:29:46]
Israel Gottlieb - Posts: 14
Given a price value, is there a straightforward way to determine its relative position on the chart, i.e. percent distance from the bottom?
IG
[2014-03-30 20:49:51]
Have a look at the Tools >> Chart Calculator tool.
[2014-03-31 17:33:05]
Thanks for your reply.
It seems I did not clarify my question properly.
I'm developing for Sierra. I need to obtain the percent position for a given price -- programmatically, i.e. in code, so I can use it to determine where to draw a nearby drawing, using s_UseTool with UseRelativeValue. As far as I can tell, the reference you gave applies to the Drawing Tool available to a user of Sierra Chart, but not to the api.
Much Obliged for any help,
IG
[2014-03-31 17:49:05]
Percent position relative to what?
[2014-03-31 18:05:52]
One way to set the Tool.BeginValue/EndValue of the UseTool drawing tool, is as a percent of the total screen height. I want to find this relative position on the screen, for a given price, in code. For example, say I have an ES mini-S&P chart, with a bar that has a LOW at 1740. I want to draw a mark 2% of the screen below that LOW price. I need a function that, given a price, returns its relative position on the screen. Say it returns 37% for the price 1740. Then I draw my mark at 35%. If there's another way to do go about this, please advise.
IG
[2014-04-01 09:28:05]
We are not sure how this would be accomplished.
[2014-04-02 00:30:12]
There are various ACSIL variables that give coordinate information in both pixels and prices. Refer to:
https://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html
You should be able to accomplish what you want using those.
Date Time Of Last Edit: 2014-04-02 00:31:01
