Date/Time: Sun, 02 Mar 2025 21:33:07 +0000
Weekly VbP Sunday-Friday
View Count: 575
[2021-10-26 18:50:10] |
User763002 - Posts: 30 |
Hello, Is it possible to have the VbP study go from Sunday Globex to Friday Close without updating the start time/end time each week? I have a rolling weekly VbP but I want to start new every week automatically if that is possible. I have attached a screenshot and the far right VbP is my rolling weekly. Thanks |
[2021-10-26 23:28:10] |
John - SC Support - Posts: 38292 |
The only way to do this would be use the Volume Graph Period Type of Multiple Profiles Based on Fixed Time where the Time period is 1 week. The most recent profile will be the current week. Refer to the following: Volume By Price Study: Multiple Profiles Based on Fixed Time You can then use the option for Always Display Last Profile Within View to be able to keep the current period in view. Refer to the following: Volume By Price Study: Always Display Last Profile Within View Otherwise, if you are wanting just a single profile, you would have to use one of the options that defines a Start Date-Time and update that value once a week for the current week. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-27 12:43:14] |
Awesome thank you for the help
