Date/Time: Sun, 02 Mar 2025 22:04:21 +0000
[User Discussion] - Alert Manager - disable alert execution message
View Count: 453
[2021-10-26 18:23:35] |
andreaslovesstocks - Posts: 12 |
Hello, When using the Alert Manager under ''log'' after an alert was triggered I get approximately 2-3 seconds later another message on the manager that the ''alert message was sent successfully'' - this is doubling the entries I have for my alerts and reduces the overview overall. Is there any option to disable this message? Thank you. |
[2021-10-26 23:19:44] |
John - SC Support - Posts: 38292 |
Most likely you are sending an email with the Alert that you have selected. That will create a second line that has that message. There is nothing to be done about this, as that line is letting you know that the email was sent successfully.
