Date/Time: Sun, 02 Mar 2025 21:47:54 +0000
Developing VPOC coloring on TPO Chart?
View Count: 684
[2021-10-26 17:58:09]
Jeff Li - Posts: 58
Hi, is there a way to track the VPOC on TPO at the start of each letter period?
[2021-10-26 18:11:27]
John - SC Support - Posts: 38292
Not within the TPO study itself. But you can get the VPOC for candles by using the following study:
Volume Point of Control for Bars
If you set the bars to be the same time as each period in the TPO (30 minutes for example), then you would see the VPOC for each period in that candle chart.
[2021-10-26 18:56:23]
Jeff Li - Posts: 58
Thanks, I want to keep track of the VPOC of the day. The study you linked seems to calc the VPOC of each 30m candle
[2021-10-26 23:32:06]
Sorry, we think we misunderstood what you are looking for. There is still not a way to do this within the TPO itself, but refer to the following which can give you the developing Volume POC:
Volume Value Area Lines
If you are looking for the TPO POC (not the Volume POC), then refer to the following:
TPO Value Area Lines
In either case, there is an Input for Draw Developing Value Area Lines. You will want to set this to Yes for what you want.
