Date/Time: Sun, 27 Sep 2026 06:01:31 +0000
trade on bitmex with ETHUSD
View Count: 863
| [2021-10-26 15:09:34] |
| Kurt Degeest - Posts: 1 |
Dear, I would like to trade on bitmex with ETHUSD. The data feed on this moment comes from CQG but trading it gives the following error (see files in attachement). What should I do to trade ETHUSD? thanks https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=56142 |
| [2021-10-26 15:58:33] |
| John - SC Support - Posts: 48028 |
You would need to install a second Sierra Chart and connect that second one to Bitmex. Your first installation would stay connected to CQG. Refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart And refer to the following for how to setup trading with Bitmex: BitMEX Trading Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
