Date/Time: Sun, 02 Mar 2025 21:42:49 +0000
OEC data down and no connection
View Count: 446
[2021-10-26 13:48:01] |
User821047 - Posts: 14 |
the Gain capital OEC data connection is down. no connection 1 hour ago
[2021-10-26 14:28:01] |
User37462 - Posts: 31 |
The same to me. No connection about 50 min now.
[2021-10-26 14:52:45] |
OK now.
[2021-10-27 01:49:31] |
the Gain capital OEC data connection is down again
[2021-10-27 01:59:56] |
This is not something that Sierra Chart has any control over.
