Date/Time: Tue, 26 Nov 2024 04:01:04 +0000
[User Discussion] - point and figure wyckoff calculation
View Count: 3387
[2014-03-29 19:30:19]
User92118 - Posts: 1
hello
I am looking for point and figure with wyckoff style calculation. Currently, only eSignal and Tradestation have this. In tradestation the setting is under format symbol. It is called enable one step back column building. In eSignal, you right click the pnf chart, select edit chart, then select the Wyckoff Calculation checkbox. Both give PnF charts according to the wyckoff method. Please let me know if this is something you can build as part of the PnF features in Sierra.
thank you,
Rassul
