Date/Time: Sun, 02 Mar 2025 21:04:45 +0000
Stock Symbols on Data Feed from Interactive Brokers
View Count: 667
[2021-10-26 04:36:28]
BillyBear888 - Posts: 4
On newer versions of Sierra Charts, 2320 and 2322 & previous versions , Sierra Chart does not recognize stock symbols on Interactive Brokers and therefore intraday data feed from Interactive Brokers cannot be loaded on Sierra Chart. The format for stock symbols can be found via Interactive Brokers Symbols: Stock Format
imageimage (2).png / V - Attached On 2021-10-26 04:30:21 UTC - Size: 67.78 KB - 190 views
imageimage (1).png / V - Attached On 2021-10-26 04:30:40 UTC - Size: 47.86 KB - 190 views
[2021-10-26 14:53:01]
John - SC Support - Posts: 38292
Those are messages from IB. As they state, you need to include the Currency with the symbol.
You really need to ask IB for any additional help with regards to the symbols you need to use.
