Date/Time: Thu, 10 Sep 2026 16:34:21 +0000
Spread Data Not Updating
View Count: 754
| [2021-10-26 03:46:16] |
| YMllc - Posts: 36 |
CBOT spreads (grains for sure, maybe others) have not updated or received price data since 10/18/21. Has there been any resolution to this?
| [2021-10-26 14:44:01] |
| John - SC Support - Posts: 47833 |
We just checked KEZ21-KEH22 spread and the data for this is up to date. Can you please give us the exact symbol for which you are having an issue? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-10-26 14:51:28] |
| YMllc - Posts: 36 |
yes, all corn spreads for me. ZCN22-ZCZ22, ZCZ21-ZCZ22, etc also noticing issues on CME Live Cattle Spreads. specifically LEZ21-LEG22 |
| [2021-10-26 15:01:47] |
| YMllc - Posts: 36 |
file attached...LC data now only showing up to 8/31/21
Private File |
| [2021-10-26 16:08:07] |
| Sierra_Chart Engineering - Posts: 24822 |
This issue has been resolved. Update to the latest prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
