Date/Time: Sun, 02 Mar 2025 20:53:49 +0000
from Sierra only to Sierra with Denali
View Count: 451
[2021-10-26 00:54:35]
User519919 - Posts: 6
i have payed Sierra Advanced Package, and renew is at Feb 2022.
Must i pay completely new Package or can i pay the difference for Sierra with Denali Data Feed?
best regards
[2021-10-26 14:19:25]
John - SC Support - Posts: 38292
We see you are on Package 11 already, so it looks like you figured this out, but below is the information regarding changing your package:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
