Date/Time: Sun, 02 Mar 2025 21:07:31 +0000
Profile view
View Count: 536
[2021-10-25 19:18:03] |
amazayn - Posts: 48 |
Hello, I am trying to get my profile to show only for the current week, and not the last 5 days (this setting works if it's Friday) but for example, on a Wednesday, I only want to see the profile for Monday - Wed. Here is a screenshot of what my current setup is.
[2021-10-26 00:02:43] |
John - SC Support - Posts: 38292 |
You would have to use Volume Graph Period Type of From Start Date-Time to End or From Start Date-Time To End Date-Time depending on which one is a better fit for you. You will have to update the Start Date-Time and End Date-Time occasionally as well depending on the settings you use. Refer to the information for these options in this section: Volume By Price Study: Volume Graph Period Type For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-26 01:38:54] |
I was trying to avoid manually putting in those dates weekly to get what I wanted. There is no other way to automatically have this done?
[2021-10-26 14:39:47] |
The only other option would be to setup Multiple Profiles for Time Period, but given that you have other Profiles on your chart, this would not be a good option. Also, if you have a TPO profile chart, then that is not an option. Therefore, the best option is what we gave you above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
