Date/Time: Sun, 02 Mar 2025 21:23:59 +0000
Is their a place to make my watchlist rotate by itself ?
View Count: 394
[2021-10-25 19:07:24] |
GravisHTG - Posts: 306 |
Like change symbol every 10 sec ? Or do I need to do a custom study for it ? I already know the scanning , but its too fast and I cant find a way to make it change each 5 sec or something like that. thanks Date Time Of Last Edit: 2021-10-25 19:19:08
[2021-10-25 23:58:27] |
John - SC Support - Posts: 38292 |
The Continuous Scanning option timing is controlled through the Chart Update Interval. Refer to the information here: Chart Menu: Enable Continuous Scanning (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
