Date/Time: Sun, 02 Mar 2025 21:19:43 +0000
[Programming Help] - TPO Chart Values and merging
View Count: 437
[2021-10-25 18:27:11] |
PanCSI - Posts: 9 |
Hi. I am doing some development on Sierra Charts trying to build a strategy that works with some information extracted from the TPO Chart Values indicator. I need some of the features of the indicator to be available programmatically, such as being able to merge one with the following. On the other hand, I don't need some of the existing features. I was wondering if Sierra Chart can make the original code for that indicator available, so I can work on top of it, or at least part of that indicator, which generates the profiles and value areas, and I can work on top of that and integrate it with the strategy I am implementing. Thank you very much for your time. |
[2021-10-25 23:54:20] |
John - SC Support - Posts: 38292 |
Refer to the following: How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
