Date/Time: Tue, 26 Nov 2024 03:56:41 +0000
[User Discussion] - SC newest version - layout changes?
View Count: 1091
[2014-03-29 18:48:01] |
Luke - Posts: 142 |
I just downloaded the newest version of SC to a VPS that I am currently testing and noticed that there are some layout changes, even though the settings seem to be the same as with my existing SC versions. The line style of the horizontal chart grids is set to "dot", as with my old charts, but the grid in the charts of the new version is actually not dotted, it is an uninterrupted line. Also all numerics and letters seem to be a different font (even though I couldnĀ“t find any changes in the graphic settings)
[2014-03-29 20:07:06] |
There were no changes with either of these. Does anyone else notice a change with these specific items mentioned? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-29 20:07:20
[2014-03-30 00:59:04] |
M5amhan - Posts: 468 |
nothing changed for me http://www.sierrachart.com/image.php?l=1396141131195.png |
[2014-03-30 17:38:09] |
Luke - Posts: 142 |
I just made a screenshot of the chart on the VPS and had a look at it on my normal computer. The problem seems to be with the screen display of the VPS, if I look at the grid line of the screen shot on my normal computer the line is dotted, as it is supposed to be...
Date Time Of Last Edit: 2014-03-30 17:49:14
