Date/Time: Sun, 02 Mar 2025 21:11:34 +0000
Update Symbols w/ Custom Settings Disappeared
View Count: 429
[2021-10-23 17:00:24]
user_xyz - Posts: 449
Upgraded SC to latest release and Rithmic symbols needed to be updated from the dash to dot format eg. CLZ1-NYMEX to CLZ1.NYMEX. Previous symbols had custom settings like commissions, times etc added which didn't translate to the new format/symbols.
Is there a way to copy, merge or retrieve those settings over?
A way to keep both symbol formats because all trade data YTD is now wildly wrong eg. I think price multiplier change old crude contracts show .75 when they should be 75.xx?
Thanks!
Date Time Of Last Edit: 2021-10-23 17:09:26
[2021-10-25 15:14:27]
John - SC Support - Posts: 38292
Sorry, but there is not a way to copy the data over. You can view the differences in the Global Symbol Settings and then update the new symbols with the old information. Refer to the following:
Global Symbol Settings: Instructions
