Date/Time: Sun, 02 Mar 2025 21:05:40 +0000
splitting chart
View Count: 1175
[2021-10-22 19:36:27] |
User178126 - Posts: 1 |
Hi, Can't find in docs how to split chart into separate 2 sections like https://prnt.sc/1x4h9dn I know its possible to attach detach/charts, but in the single screen situation would like to have chart split into 2/4 sections without detaching like in the example above, thanks |
[2021-10-22 20:42:12] |
John - SC Support - Posts: 38292 |
You would use one of the tiling options under the Window menu. For example, if you just have 2 charts, then you would select Window >> Tile Vertically to get what was shown in your image. Keep in mind that generally, once the charts are un-maximized then you can place them anywhere within the main window area. Also, refer to the following setting, which allows you to have virtual space within the main window area: General Settings Window: Enable Workspace Scrolling (Global Settings >> General Settings >> GUI >> Scroll) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
