Date/Time: Sun, 02 Mar 2025 20:51:40 +0000
way to switch to
View Count: 418
[2021-10-22 10:45:36]
HeyUgly - Posts: 251
hello
basic question any way to do this?
number bars dont work in historical format, so wondering any way to switch intraday charts when on a 30min or whatever to a daily on the number bars, and not have chart auto change to historical?
thanks!
[2021-10-22 16:16:39]
John - SC Support - Posts: 38292
Refer to the following setting, which you would want to set to "Intraday Chart Only:
Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu)
