Date/Time: Sat, 01 Mar 2025 20:33:13 +0000
Malware Detected
View Count: 599
[2021-10-22 00:14:36] |
IntrepidTrader - Posts: 2 |
Hi Support, I am using SC on a Mac using Crossover/Wine & my Sophos Endpoint protection has detected malware in the two files attached. My security dept has confirmed the same on a Windows machine and recommended you look at this: https://www.virustotal.com/gui/file/50dad2f780adeaeebfc201ca6338c382f86f83c8f2432d24c46776219bb6cfd7?nocache=1 Thanks |
![]() Attachment Deleted. |
[2021-10-22 05:54:20] |
Regarding this, refer to: Software Download: Antivirus/Anti-malware Software Flagging Sierra Chart Installer or other Files as Unsafe/Infected Also the file you are referring to is not a Sierra Chart file. We do not know where that came from. It is not from Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-22 05:55:24
