Date/Time: Sat, 01 Mar 2025 20:06:59 +0000
CME Data
View Count: 626
[2021-10-21 15:40:02] |
User120666 - Posts: 46 |
Hi - can you please confirm which CME package I need as a non pro and without a funded futures account. I already have Denali Package 11 with Eurex, but I need the mini Nasdaq (NQZ21-CME) and I want to track Numbers Bars and profiles etc. Do I need the: CME E-mini, For professionals and users without a trading account at 62.40 USD / month? Will that give me the mini Nasdaq with full Numbers Bars capability? |
[2021-10-21 17:35:55] |
John - SC Support - Posts: 38292 |
Since you do not have a funded futures trading account, then you will need to pay for the Professional exchanges. The "CME E-mini, For professionals and users without a trading account" does have the NQ on it, so it would be your cheapest option in this case. But, if you are not considered a professional by the exchanges, then we recommend looking into the service at the following link which allows you to create a trading account for as little as $200, which can then be used to verify your Non-Professional status: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-21 17:41:36] |
OK thank you... so if I get a funded futures account setup, what CME data option would I need then? Is it the one for $10p/m?
[2021-10-21 18:23:53] |
It would depend on whether you need Market Depth data or not. If you need the Market Depth and you are just trading NQ (or other instruments on the CME Exchange) then you would want the CME with Market Depth for nonprofessional Trading accounts for $10.40 per month. If you do NOT need Market Depth and you are just trading NQ (or other instruments on the CME Exchange) then you could do the CME non-professional top-of-book for $1.25. Or, if you do not need Market Depth and you want the entire CME Group, then you could do the Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts for $3.25. And finally, if you just want the whole thing (Full CME Group with Market Depth) then you would do the Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts for $31.20. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-21 19:19:52] |
I just need mini Nasdaq only and just the realtime bid/ask data for Numbers Bars and volume profile etc - which would that be?
[2021-10-21 21:09:54] |
Use the CME non-professional top-of-book at $1.25 per month for what you need.
