Date/Time: Tue, 06 Oct 2026 09:48:33 +0000
Denali with AMP Global and IBKR
View Count: 884
| [2021-10-20 10:50:09] |
| User587833 - Posts: 1 |
Hi, Currently on CQG and AMP global but I'd like to move over to Denali. With a Denali only data feed, will I be able to trade on both AMP and Interactive Brokers in 1 PC system? I've installed a new setup of SC for a new trial IB account and it's working fine. Thanks and regards. DH |
| [2021-10-20 14:58:14] |
| John - SC Support - Posts: 48114 |
You can do what you suggest. The only thing that you will want to do is to have 2 different installations of Sierra Chart, one for the connection to CQG and the other for the connection to Interactive Brokers. The Denali Exchange Data Feed allows for 2 connections at the same time from the same computer, so there are no additional fees associated with this setup. Refer to the following for information on how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
