Date/Time: Sat, 01 Mar 2025 20:22:37 +0000
Sharing of chartbooks
View Count: 1199
[2021-10-19 17:45:12]
User449884 - Posts: 166
Is there somewhere to share chartbooks on here ?
[2021-10-19 17:57:20]
John - SC Support - Posts: 38292
You can do it directly from within the Sierra Chart software if you like. Refer to the following:
File Menu: Send File to User (File)
You can post your chartbook to this Support Board, but it will be available for everyone to see/access.
If you are going to use the Support Board to send information, then just be sure to mark the post as "User Discussion". That way, we will ignore it as we go through our process of answering questions.
