Date/Time: Sat, 01 Mar 2025 20:08:47 +0000
[Programming Help] - 'Auto Retracement/Projection' needs some update please
View Count: 785
[2021-10-19 17:24:18]
User392279 - Posts: 67
When I use this indicator, I'd like to use ATR data for projection/retracement. Would you please make it possible? I would like use different length of ATR for different projection level. When the bar hits daily high or low it will automatically project possible high or low compare to history ATR. If I'm not make myself clear please advise. Thank you very much!
[2021-10-19 17:52:44]
John - SC Support - Posts: 38292
You can use the Auto Retracement/Projection study on the ATR data. Refer to the following:
Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study
We are not sure exactly how you want to be able to tie the information from the Retracement/Projection of the ATR back to the main Price Graph, but you could always use the Arithmetic studies to multiply the data by some amount. Refer to the following:
Using the Basic Arithmetic Studies
[2021-10-20 01:37:29]
Hi, Thanks for the tip. But after I tried. It seems not possible? Need to refere to daily ATR value to short time frame chart. Based on current day high/low range and compare to ATR value to make a projection. So data has to come from a daily chart? The subgraphs study not able to input data from a different tab? Would you please help me to make it?
