Date/Time: Sat, 01 Mar 2025 20:25:30 +0000
Unable to login to Sierra chart
View Count: 486
[2021-10-19 17:21:16] |
User513302 - Posts: 2 |
I have just started the trial today once I figured that I can run sierra chart on mac using crossover. However when I logged in i am unable to load any chart for the symbols. I could see a red tab at the top saying "Not connected" even though I am logged in See attached screenshot. My account seems to be showing as not activated for the trial. Can you help fix the issue. Kind Regards |
[2021-10-19 17:43:03] |
John - SC Support - Posts: 38292 |
When you try to get a trial on a Mac, it automatically gets rejected by our Trial Analyzer since the Computer Hardware ID is NULL. We have manually reset the trial for you, so you should be good now.
[2021-10-19 17:48:07] |
Thanks. I can now login and load charts
