Date/Time: Sat, 01 Mar 2025 19:45:27 +0000
f.us.clez21
View Count: 499
[2021-10-19 14:06:59]
amirN - Posts: 159
What is the equivalent symbol for F.US.CLEZ21 in Denali datafeed? I have tried to use CLZ21_FUT_NYMEX but they do not match up.
[2021-10-19 16:06:00]
John - SC Support - Posts: 38292
The symbols are not set by the data feed. They are set by the setting for Global Settings >> Data/Trade Service Settings >> Current Selected Service.
Therefore, if your Current Selected Service is set to CQG, then you will continue to use the F.US.CLEZ21 symbol.
If you change your Current Selected service, you can update your charts to the new symbols by selecting Edit >> Translate Symbols to Current Service.
[2021-10-19 16:32:21]
amirN - Posts: 159
I have used that, and the translated symbol is CLZ21_FUT_NYMEX for SC/TT Futures Order Routing. However, when I compare it to someone that is using CQG the data are close but do not match.
[2021-10-19 17:32:13]
There are lots of possible reasons for why the data do not match exactly, even within the same data feed, as there are a lot of settings that go into determining the particular bars. Refer to the following:
Differences With Data and Chart Bars Between Services / Connections / Chart Types
