Date/Time: Sat, 01 Mar 2025 20:39:02 +0000
flux direct
View Count: 590
[2021-10-18 19:07:58] |
User338651 - Posts: 14 |
bonjour a vous j'aimerai avoir des flux réel, pas décale, comment faire s'il vous plais?
[2021-10-18 23:44:07] |
John - SC Support - Posts: 38292 |
From Google Translate: hello to you I would like to have real flow, no shift, how to do it please?
What are the exchanges for which you want to have real-time data? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-20 15:51:15] |
j'aimerai si possible un flux direct pour le SP500 comment faire , donner moi la marche a suivre s'il vous plais cordialement |
[2021-10-20 16:19:30] |
From Google Translate: I would like if possible a direct stream for the SP500
how to do, give me the procedure please cordially We need to know which SP500 it is that you want the data for. There is the CFD SPX500, for which we have the data available at no extra cost. Refer to the following for this data: Sierra Chart Real Time and Historical Forex and CFD Data Service And there is the e-Mini (and micro) S&P 500 Futures from the CME Group. To get this data, you would go through the Setup Instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Note that for the CME Group data, you will need to have a live, funded, futures trading account to which you can connect your Sierra Chart software. For more information refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
