Date/Time: Sat, 01 Mar 2025 19:36:45 +0000
mouse behavior
View Count: 426
[2021-10-18 16:44:37]
User427561 - Posts: 217
when I select a chart or region, I can only move the selection verically not horizontally, How come ?
[2021-10-18 17:52:47]
John - SC Support - Posts: 38292
If you are referring to the Hand tool, then refer to the following:
Chart Drawing Tools: Vertical Movement and Scaling
If it is something else, then we need more information on the specific issue.
