Date/Time: Fri, 18 Sep 2026 15:52:38 +0000
Disconnecting and reconnecting
View Count: 672
[2021-10-18 16:14:39]
User664240 - Posts: 209
I sent the log. Similar to previous issue.
[2021-10-18 17:48:40]
John - SC Support - Posts: 47934
You are getting the following messages in your log:
DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
You are having connectivity issues. Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
