Date/Time: Sat, 01 Mar 2025 19:11:01 +0000
Gap on chart rollover, tried everything
View Count: 631
[2021-10-18 14:45:57] |
User449884 - Posts: 166 |
Rolled over CL to CLz1, and now major gaps in the chart. No way to have prev contracts. I have the volume based rollover option ticked on. I redownloaded data several times and nothing
[2021-10-18 16:04:08] |
John - SC Support - Posts: 38292 |
If the gaps you are referring to are price gaps (not time gaps) then you need to use a Back-Adjusted continuous contract in order to not have the price gaps. Refer to the Continuous Contract options starting here: Continuous Futures Contract Charts: Continuous Futures Contract - Date Rule Rollover, Back Adjusted For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-18 16:38:03] |
the gaps seems to be from sept
Date Time Of Last Edit: 2021-10-18 16:46:51
[2021-10-18 17:55:29] |
What is the symbol of that chart and what is the frequency (time settings) for the TPOs? Have you tried Edit >> Delete All Data and Download? If not, then select that option and select all the contracts that come up. Let us know if this does not resolve your issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-18 18:14:41] |
the symbol is CLZ1.NYMEX here is a snap of the time settings |
[2021-10-18 18:28:10] |
resolved, had to get NYMEX feed seperate. weird cuz it was working fine till i rolled over
